Hmmm. A sad read indeed. I wonder whats going on with it......
Defo need to find the source of the leak before attempting to fix anything. You suggest that water is coming in good quantities - which is good - it should make it easier to troubleshoot.
I had a nightmare with an A2 a while back, its sunroof drains had blocked and all the water had run down the headlining into the boot. Totally soaked the carpets and boot area, floor carpet, back seats. Took forever and them some to dry out the dam thing, but now, with clear drains and dried interior its good as new. For a long time I thought I hadn't fixed the leak, but it turned out to be the same water evaporating and condensing on the windows time and time again. A good few sunny days with the windows left down and the moisture escaped....
In terms of troubleshooting your car I can only state the obvious - water flows downhill, so if its in the battery compartment, it came from above, somewhere. Also, my driveway is flattish as you know, and I never had any such issues, I wonder if you regularly park it at some angle that triggers an issue I never saw ?
I also agree with others about the plastic window trims - They are purely cosmetic, the window is bonded beyond that.
The LPG filler is an obvious "aftermarket" addition, but the D3 flap seals quite well iirc, so I dont really see what would have changed to make it suddenly leak in.....
I hope you get it sorted....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
