Thread: LED porn
Old 6th May 2014, 08:05 AM
Also, fog lights use to be designed with a very flat but wide beam intended just to pick up kerbs and other roadside objects so you could slowly proceed in real pea-soupers. The flat beam from lights mounted low down meant that backscatter was reduced. And as HP mentions yellow reduces backscatter too.
