DTCs he is getting with a very similar problem to yours.
Tried calibration. Sometimes it's fine for days but one run over rail track and abs and esp kicks in instantly which indicates some connection problem.
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0096931
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 3365F05952BA9686591-8066
2 Faults Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 191879 km
Time Indication: 0
Date: 2013.10.05
Time: 13:15:08
Freeze Frame:
RPM: 1984 /min
RPM: 1952 /min
RPM: 2848 /min
(no units): 70.0
(no units): 31.0
Temperature: 40.0°C
T.B. Angle: 26.3°
001923 - Shift Monitoring
P0783 - 000 - 3-4 Shift - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 195897 km
Time Indication: 0
Date: 2013.11.09
Time: 19:51:52
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224B051DFD400F0EA27-8077
3 Faults Found:
00003 - Control Module
014 - Defective
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
