Old 25th May 2014, 06:03 PM
Greg try pulling it out of park before you start the engine. (Start in neutral) and take 5 second gaps when swapping gears
And clean all the plugs and connectors under the car around the gearbox you can see with gt85 or wd40 ect
It worked for me!!!!!
I'm not promising anything mind your fault could be different to mine!
If the ECU doesn't see the correct values it will go into fault mode
And I wouldn't even let the brake off or try and move the the car with the dash gear indicators all lit up.
Good luck
Isn't it time we got a good deal from Audi for brand new transmissions?
Cheers dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
