Originally Posted by David's8
I guess that a "message" is sent between the central locking module and the sunroof module telling it to shut the sunroof. But has the sunroof been open? If its already shut why would it blow? Does it blow when when you try to open/ shut the roof using the normal control switch? (do you use a sunroof in Norway  )
No, sunroof is just for display purposes
The sunroof was closed when this happened. I just pressed the keyfob thingie to lock the doors and nothing happened. Then tried manually locking it with the key but only drivers side would lock..
The fuse blows the second do the following
-Press the keyfob to lock or unlock
-pressing down the doorknob on driver side.
I have had a CL error message in vag-com for quite a while regarding the CL pump running a bit to long(possible leak) but it has despite the fault code been working flawless..
