Old 16th June 2014, 05:23 PM
Hi David
Just very quickly as it's mental on my end.
Just to clarify
You've installed a ABS module from W12??
What info you have used from W12?? Coding is a combination of brake calipers etc on the car you fitting it (info on the sticker from your current car not donor), therefore you can't use the W12 coding as this has different components installed. As far as I'm aware. Someone correct me if I'm wrong.
Is a W12 module compatible with 4.2 at all?? This one I'm not sure.
And to clarify, yours is 4.2 petrol ??
