Thread: Aux Heater
View Single Post
Old 16th June 2014, 06:23 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Sorry bout the late reply M-A8.
In to HVAC and just add 2 to what ever coding you got.
Mine was 49 on the end, so it went up to 52.
Turn the ignition off and on and it's there. Sorted.
The engine don't start. The little diesel burning under the air box fires up. You can hear it humming.
That's for the Aux heat.
It will warm up the coolant, pump it round the engine and heater matrix. It's not boiling hot like the engine does, but enough to melt ice and take the chill out of air on the cold mornings.
I set the aux fan up to turn on for 45 minutes before I finished work and to run for 45 minutes. The cabin was cooler and it never took any bars from the battery monitor.
Happy with this little mod.
[center]
06 3.0TDI Quattro:
Options:
