  #30
Old 9th July 2014, 12:32 PM
Bandycoot Bandycoot is offline
The plot thickens. I did another scan yesterday and all sorts of horrors have now turned up. Take a look at these:
9 Faults Found:
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 35-10 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-10 - System too Lean - Intermittent
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
17950 - Angle Sensor 1 for Throttle Actuator (G187)
P1542 - 35-10 - Implausible Signal - Intermittent
17796 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 35-10 - - Intermittent
This throttle body is still showing the same fault codes as the one it replaced so I'm not convinced it's this. I'm going to have the electrical connections checked on the throttle body and the MAF, this was new six months ago, as the Ross Tech wiki says this could be a cause of these fault codes.
I'm more and more getting to the opinion the fuel injectors are on the way out. After almost 300,000 kms they are entitled to feel a bit knackered. The fuel trim fault codes suggest faulty injectors could be the cause. I'm getting a lumpy idle and I'm down on power which could support this.
As for the lambda probe, B1 S1, which one is this? Is it the pre cat lambda on the left hand bank as looking at the engine from the front of the car?
I took the car out today and the only the Traction control and ABS lights came on and then not all the time. in slow moving traffic they would come on when I stop and would go out when I moved away. One interesting thing happened a few hundred yards into my journey. I had just gone slowly over a speed but and was moving away when the engine just cut out. It started again easily but it had never done this before.
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
