View Single Post
Old 10th July 2014, 11:10 AM
andycaca andycaca is offline
rivnuts can be a bit of a pain to fit if you havent got the right tool to prevent it spinning. its possible to fit them with a couple of nuts on a bolt to provide the right tension, but if you stop tightening a little early you will be left once more with a spinning rivnut!
it might be worth your while either practising on a bit of scrap or buying/renting the correct tool.
