Old 6th August 2014, 09:34 AM
If you're lucky, it might just be a blown head gasket (or both head gaskets as it's cylinders 2 and 5). Ask if there's any oil in the water/water in the oil as this might support this theory. And ask their thoughts as well.
Then, depending on how 'cooperative' the garage might be, I'd asked them to remove the heads, check the gaskets and check for any warping of the heads/blocks. And see if you can agree a deal for this (preferably FOC) as I'd suspect thae garage has caused this problem, even if only by advising you to continue driving the car on 2 occasions!
Once the heads are off, they should be able to see the extent of the damage and advise you on the prognosis.
Fingers crossed for you!
