Old 11th August 2014, 04:52 PM
Here's one for the hard up...
Remove the rear seat squab and collect the money.
I had £1.90 under mine.
I did it because I had an airbag code due to tarnished connection under the seat - I cleaned all the connections with alcohol spray and vacuumed it out and wiped it down and cleaned the edges of the leather.
You should disconnect the battery first due to the airbags in the backrest.
You remove it by opening the door and bending/lifting up the outer edges of the squab unit untill that side pops out of the retainers, then do the other side and it should lift free.
