Originally Posted by Daz 70
I've not really found a suitable switch I like the look of as I would like it to look stock rather than some hack.
Sergey discovered a while ago that the PF switches fit the small blanking panel to the right of the ignition switch in the FL '8s.
Even better, if you want a simple on /off switch (avoiding relays), then you can use the hazard warning switch and change the cover plate with one from another switch. That's going to look as 'stock' as you'll get.
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .
