Thread: 255's vs. 275's
Old 20th August 2014, 09:18 PM
Lee, Richard, Thank You
Reason I'm asking is because there is a diameter difference between most of the OEM sizes.
Lets say stock is 255/45/18
If you use any of the following, 265/35/20 # 275/35/20 # 275/30/20 # 255/35/20, the actual diameter is between -7mm to +14mm from the diameter of the stock 18" wheel which has 255/45/18 tyre fitted
