Old 1st November 2009, 03:46 PM
They're erm.. what's the word..
Oh yes.. Wrong.
If you have the latest MMI (5150 or 5570) then you can drop MMI in (I think it needed 3120 as a minimum).
You have 2 options.
1 - Easiest - Just replace the CD Changer with the AMI unit. Keep the CD Changer so you can perform updates if any ever come along (what I did)
2 - Bit more fiddly, but not too bad - Keep both and replace the pigeon hole in the glovebox beside the CD changer with the AMI. Needs soem new wiring/fibre components and the MMI told that it has another media unit, but still perfectly doable.
