I do indeed have a set of RS6 rears on my project car, but it's not a straight forward fit. The carriers have the same bolt pattern but they are about 3 mm out for offset. I had 3mm machined of the mating faces of the carriers to sort out the offset then found that the bolt points on the hub carrier meant that I had to have the disks reduced in size. I cant remember how much they were reduce as I did a guestimate first time and it wasn't quite enough. So had a bit more taken off and still had to file a small amount out of the gullet of the carriers as they were 'just' rubbing.
I wouldn't do it again as my PF D2 now feels a bit over-braked at the back (I have an AP racing custom set up on the front, 6 Pots with 385mm disks and DS2500 pads with are retina detaching). I also had a staggered tyre set up with 10s using 285s on the back and 8s using 255s on the front so understeer with over-braked rear end made it interesting with the back end braking loose very easily and the ESP going nuts!
HtH
