Agreed,
I need to run through the settings for HVAC on VAGCOM, its just finding all the right block data so I can confirm the range of movement is correct.
Also my laptop battery decided it would not last longer than 3 minutes on a full charge so had to order another one.
I am not sure if I need to run through output tests for the flaps to move full range and reset or if I need to go through basic settings and reset one of the blocks?
