Hi Andy, now you've got that far it's a no brainer having a look. Replace that plastic pipe anyway now you’re in there. Check the thermostat as well as the block corrodes around the hole. Take the cam covers off, you might have to let the rads go at the top to give you a bit more room to check the water pump. Only other thing I can think of is the rad its self weeping and its running back down the pipe?
