Thread: Coolant Leak!
  #30
Old 28th August 2014, 10:41 PM
gninnam gninnam is offline
Hi Andy, now you've got that far it's a no brainer having a look. Replace that plastic pipe anyway now you’re in there. Check the thermostat as well as the block corrodes around the hole. Take the cam covers off, you might have to let the rads go at the top to give you a bit more room to check the water pump. Only other thing I can think of is the rad its self weeping and its running back down the pipe?
Will check the other bits tomorrow (after getting the oil cooler back on........)
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
