Old 31st August 2014, 09:06 AM
gadgetmind gadgetmind is offline
BTW, to depressurise the diesel lines, I guess I just pull the right fuse/relay, start the engine, and wait for it to die?
Anythings I need to know about bleeding the system afterwards? Your docs (thanks again) suggest driving it and reseting if you get an error, but also mentions a bleed procedure.
My other guide just says the engine will run rough until it's cleared out any air that gets in.
