Old 16th September 2014, 12:20 PM
Will the different rotational speeds between the 235/30/19" on the front and 265/30/19" on the rear not upset the ABS and traction control, normal advice is to get as close to the same overall circumference all round. 235/30 will have significantly less sidewall than a 265/30, some 18mm less in the diameter. remember the /30 is a percentage of the tyre width and not a fixed size, 235/35 is much close in diameter to 265/30 with a difference of 5mm.
