Old 22nd September 2014, 03:52 PM
I found it easiest to ring All German Parts to find out if there's a full kit - you will then need to check that the full kit actually includes all the bits you need, as some may be non-Sport spec etc.
Worth a visit to TPS as well to ask them to print you off the correct Audi part numbers for your exact vehicle VIN and use those to cross reference part numbers - takes the guesswork out of it
