had a play with the transmission recoded it from 00101 to 00111 seems to have made it a lil bit better but not much its still a bit jerky when in drive and pushed beyond 4k rpm and kick down used if in tiptronic you can go right upto the rev limiter almost (don't wanna push to hard) and then change with no jerking i checked the engine RPM with gearbox input RPM and output RPM the engine and input RPM match slightly with a small discrepancy manageable but on the output RPM it seems to start off matching but when you push it the revs drop so if input is 4k RPM output is around 2K to 2.5K so seems to drop is this normal or have i got a sensor issue in the box no faults recorded other than the over revving on the jerking MAF is running normal within the elsawin specified 0.3% allowable difference between actual and specified in the address codes on engine any further help e of a great help thanks
