This is the state externally of my alarm module and the wrecked plug
Looked online and it appears the plastic part of the case can be dismantled, so if I can grab one from TPS this morning I should be able to clean up the contact with spray cleaner, assuming I can get it out with the barbs intact!
I'm usually OK at doing stuff like this, but the limited access will certainly make it interesting....
