Hi Adrian
With the spec of the laptop and current value of it in full working order I wouldn't cut the losses.
It can be done without the full strip down. I can't understand why would you need to do that if all the wiring is fine and just screen needs replacing
Surely this could be done by removing the frame, disconnecting all the connectors, pulling the old screen and fitting new one.
This is my opinion based on the picture of your screen which has no fixed wiring to the back of it which would go somewhere inside the chassis?!?!
Check this picture of your screen
http://www.ebay.com/itm/HP-PAVILION-...-/171353169295
Going by this spec this would be your replacement
http://www.ebay.co.uk/itm/Brand-New-...item417e0d0737
