Old 15th October 2014, 03:36 PM
Bit off topic but I went to access my D2 after it'd stood a few months, the battery was flat and the key fob wouldn't open the car. I'd owned it nearly nine years and had NEVER used the key in either the door lock or boot lock. A considerable amount of WD40 and a bit of patience gained me access to charge the battery, but it's the sort of problem I didn't think of until I had it to tackle.
Lesson learned, lube your locks
My boot lock was the same, which again I only discovered while I was investigating the driver's door lock issue. Couldn't even get the key in it at first, never mind turn it! It was like there was a key broken off inside; turns out it was just compacted road crud.
Lashings of lube did the trick for me too. I usually use this stuff though. Much better and longer lasting than WD40 I find.
Yes, I was in Stranraer (south west Scotland) on a Sunday when my central locking pump failed and I discovered I couldn't get into the car at all!
Damn, that must've been somewhat annoying! How did you get back in (assuming you did, and the car's not still there of course!)?
