If you had that avdi it could be a good trip but its a long way to go to test fit something and then get the CP locked down.
Would the CP reset if my original clocks would go back in?
On the older clocks there is a code to tell the cluster what engine/car they are installed in.
Is there a code like this for the A8?
The pre 100 mile change it to remove any delivery miles so the car looks newer than it is.
This can be done with VCDS as well.
[center]
06 3.0TDI Quattro:
Options:
