View Single Post
Old 23rd October 2014, 08:58 AM
If you had that avdi it could be a good trip but its a long way to go to test fit something and then get the CP locked down.
Would the CP reset if my original clocks would go back in?
On the older clocks there is a code to tell the cluster what engine/car they are installed in.
Is there a code like this for the A8?
The pre 100 mile change it to remove any delivery miles so the car looks newer than it is.
This can be done with VCDS as well.
I have never looked at coding the instrument cluster or taken one out so couldn't say what would happen to cp if you put the original back in.
There is also the possibility of remove EPROMs and reading data and and rewriting to others but again not something I have seen done on an 8. I guess there's just not enough of us that like to mod 8s so its not been done much.
