Plug a scanner into it and read what the coolant temperature is. If its giving an incorrect reading this could make fans come on all the time.
May not help but it happens with modern vw's/skodas, if the outside air temperature sensor is not working or have the wires cut/broken OR by unplugging it from the sensor it has corrosion inside THIS will make the fans stay on.
Its located at the front bumper area
"EDIT" ignore previous post though it was the right hand side
