View Single Post
Old 12th November 2014, 10:41 AM
mark_le_b mark_le_b is offline
Yep, it's likely to be the microswitch in the boot latch. Happened twice to me. Replacement is a little bit fiddly but quite straight forward.
Is it part of the latch itself, because I've tried swapping that already and still same issue. Unless they both had an issue of course
If microswitch is separate, where do I locate it and the part number to replace?
Thanks
