Originally Posted by Oli18
Now that is a mod i like!!!!
Very cool Ian!!!
So, what's the deal with obtaining these then from a donor car? Can they pretty much ordinarily only be sourced from a LWB then? and what about the front passenger seat with button?...i take it that as the seat is not a recaro sports seat, you opted not to replace that?
As always, love the passion you have for modifying the interior of these fantastic beasts!
-oli
Actually, the 'move the front seat forward' switch is one of the simpler upgrades.... Its basically a bypass that sits between the buttons on the normal seat, and the motor. So, when the rear passenger button isnt active the front seat switches are connected directly to the front seat motor, but when the rear passenger presses the button it switches the motor so its connected straight to +12 which winds the seat forward....
The donor car was an S8, so short wheel base & sports seats all round (lucky me) but ive not seen many other S8 / Sport varients in Germany with it fitted. You're far more likely to find it on a Long wheel base, but that causes problems because the carpet and lower C pillar trims wont fit as they are 8 inches longer
Without the 'bigger' carpet that comes with it, and modified lower C pillar trims then when the seats slide and lift, you will see exposed bodywork I guess....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
