Old 26th November 2014, 10:07 AM
Yep, that and a gearbox oil and filter change - all the same bits need accessing. Pretty sure the box needs dropping down a bit to access it?
Had mine done not long after buying it and it's been perfect since. There's 2 types based on VIN (different number of pins) if you plan to swap rather than attempting a clean.
