Hello Manny
Thanks for your reply
I fitted a new Bosch s5 110ah Battery tonight and then coded the battery ,once complete i cleared all the codes and then got out locked it and then unlocked and tried to start it , no joy , just kept spinning over , didnt even splutter.
Then read codes again
CDS Version: Release 12.12.0
Data version: 20130910
Thursday,04,December,2014,15:36:47:62939
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 18 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 67 6C 72 76 77
VIN: WAUZZZ4E77N016939 Mileage: 143620km/89241miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 B HW: 4E1 907 409 A
Component: 4.2L V8TDI G000AGMª0010
Revision: --H04--- Serial number: AUX3Z0G0315682
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 23450907E2202306A91-8076
1 Fault Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 22:35:42
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Bin. Bits: 00101000
Torque: 468.0 Nm
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0101837
Coding: 0000001
VCID: 3365F94752C0B386591-8066
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224B0C03FD3A2A0EA27-8077
2 Faults Found:
00532 - Supply Voltage B+
000 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G0315682
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 A HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 300BS077578755
Coding: 0000002
VCID: 2A5BE423850AF24EEA7-807F
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000031417
Subsystem 3 - Serial number: 0116.02.070000000100010022ÿ
Subsystem 4 - Serial number: 010022ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000114701
Coding: 0022529
VCID: 1C3732FBDF5E1CFE68B-8049
5 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 254
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 00:02:37
Freeze Frame:
ON
Bin. Bits: 00011111
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.23
Time: 01:30:27
Freeze Frame:
ON
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:16:45
Freeze Frame:
Voltage: 8.60 V
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 2
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:31
Freeze Frame:
Bin. Bits: 00001111
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 2
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:31
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: E5C1D71FEC949D36875-80B0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 9
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:28
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0010
Coding: 0011773
1 Fault Found:
006217 - Please check DTC Memory of Transmission Controller
P1849 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.12
Time: 00:29:33
Freeze Frame:
RPM: 84 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
(no units): 0.0
Voltage: 6.61 V
Torque: 795.6 Nm
Bin. Bits: 11000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G07NUP
Coding: 0431707
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Serial number: 63328RB40219F787R
Subsystem 2 - Serial number: 63428RB40219F21AJ
Subsystem 3 - Serial number: 63528RB40219F2D1N
Subsystem 4 - Serial number: 63628RB40219F211C
Subsystem 5 - Serial number: 63729RB40206046CD
Subsystem 6 - Serial number: 63829RB40206046BD
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 0
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
02095 - Component Protection Active
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 1
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 23:28:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 46
Reset counter: 8
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.25
Time: 00:02:30
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0112141
VCID: E5C1D71F2C949D36875-80B0
Component: Lenkradmodul H07 0090
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 57
Reset counter: 8
Time Indication: 0
Date: 2063.15.31
Time: 31:63:18
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 8
Time Indication: 0
Date: 2063.15.31
Time: 31:63:02
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 0 km
Time Indication: 0
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 B HW: 4E0 920 951 B
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3G1000959
Coding: 0000413
Shop #: WSC 00414 210 91518
VCID: 24470A1BE72E243ED0B-8071
3 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 8
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.12
Time: 00:16:51
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 8
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.12
Time: 00:16:51
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 9
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:03:05
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3B34E3D56A62CE7A7-804F
4 Faults Found:
00664 - Fuel gauge
00456 - Control Module for Access and Start Control (J518)
01407 - Flame Extinguished
000 - -
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0712581DF
Coding: F5D9DFFF70720E
VCID: ECD7A23BCF7EAC7ED8B-80B9
Address 1E: Media Player 2
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
1 Fault Found:
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:15:34
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 C HW: 4E0 907 289 C
Component: Komfortgeraet H09 0020
Revision: 00200009 Serial number: W040702150086
Coding: 0004317
VCID: 29591B2F800CF956E3D-807C
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Time: 00:15:40
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000105411
Coding: 0010101
VCID: 1E3338F3C9420EEE86F-804B
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:20:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:16:00
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D71DF7F648475F6BF5-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396BY077560494
Coding: 0000001
VCID: 2E53E833B9E29E6E36F-807B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000001232
Shop #: WSC 00353 210 91471
VCID: 204F060BF336381EB43-8075
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 0092S50150
Coding: 344530393135313035412056413030303932533530313530
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000702050031
Shop #: WSC 12336 024 394758
VCID: 3663C05341B2A6AE7EF-8063
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J72106G
Coding: 1020302
VCID: DCB7F2FB1FDEDCFE28B-8089
5 Faults Found:
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 00:01:28
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 76
Reset counter: 9
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.25
Time: 00:02:15
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
02203 - Audio / Video Input 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.22
Time: 19:46:44
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 9
Mileage: 0 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:34
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
013 - Check DTC Memory
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 00:01:28
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Can any one spot anything??????
My missus is getting a bit cheased off with me know as with 4 young kids shes not happy with me taking her car to work and now the car has passed the VIC check i can tax it if i can get it to the MOT station so i can actually drive it!!!!
My plan was to be using the car by now and posting a thread with my progress getting it all sorted , not trying to get it started ???
Now i have my VCDS working if i can help anyone in the northwest give me shout!
On another note big thanks to CARL for sorting my parts out , quality service from A8 Parts ,recommended no problem!!!!!!
2012 4.2TDI SE EXEC
