Battery coding looks ok, but wouldn't cause the car not to start.
Is it just cranking and cranking?
If you crank can someone see if gas/air is pumping from the exhaust?
You have fuel so I wonder if the shut-off / throttle is not opening?
Maybe someone who knows more about the 4.2 tdi can say.
Weird that there is no code.
Also why is there no Address 25: Immobiliser on your logs? Can you connect to it manually by choosing 25 ?
Any sign of water under the drivers footwell carpet?
