The boot hinge is worn or bent, mine was like that when I bought it, I used all the adjustment on the hinge I could and it's still not 100% right, as said above it more than likely has a powered boot as mine has, when its like that the seal at the back of the boot is not creating a good enough seal to keep it water tight so ingress could quickly become a problem.
