Old 24th December 2014, 06:41 AM
It may be worth you looking through your debug logs to see what you have changed in the past.
goto
c:\Ross-Tech\VCDS\Debug\CodingLog.txt (coding changes history)
or
c:\Ross-Tech\VCDS\Debug\AdpLog.txt (adaptations changes history)
Good luck
P.s if you have time I recommend you and everyone else to do the following it will help us all in the long term I'm sure http://wiki.ross-tech.com/wiki/index..._can_I_help.3F
