I'm having similar trouble. I fitted the RVC control module. It worked with a cheapo chinese camera until I installed it properly and then it didn't work. I brought the camera into the house and tested on TV and it was dud, I must have damaged it, so binned it and ordered a different one.
That one worked on the TV but nothing on the MMI either through the RVC module or aux in.
The wife's digital camera which has composite video - tested OK on TV and on AU- in but RVC would cut off after a second with fault code about video in open circuit or short to ground.
I now have another chinese reverse camera to try when the weather is better - not sure what the exact spec is for the video input but seems fussier than TVs.
