Originally Posted by Delboy
I vaguely remember reading somewhere the rvc module does not supply 12v feed to the camera, its something like 7v so if you try to run a camera other than oem from the rvc module you may well get problems with the camera dying or errors being thrown.
Yes, you are correct - there is a 6/7v out from the RVC module for the original camera but I am using 12v from the 12v outlet.
Still have the 'problem' of fussy input, but hopefully will figure something out.
***EDIT
Ok did some tests today.
Putting new chinese RVC camera signal into RVC ECU via a new 6" Fakra-phono adapter gives garbage scrolling picture.
Putting new chinese RVC camera signal into Aux-in on TV gives good picture.
Putting same signal into cam-in on RVC ECU gets scrolling garbage.
I am now thinking the Original Audi camera 4L0980511 is not a normal analogue composite video - probably LVDS....
https://www.google.co.uk/search?clie...DS+audi+mmi+2g
