Old 15th January 2015, 06:39 AM
Update. So the sensor is in it now works fine . However all the lights are still on the dash but on vcds the code has gone. It seems to have re set itself.
The only fault now is dtc memory of abs controller and a valves voltage supply to abs pump
Dose any one have any idea ?
The abs module was changed about 5 weeks ago and the problem was cured but now this ?
We are clueless can any one help please ?
