Old 21st January 2015, 07:22 PM
Well the Q7 wheel specs are:
10jx21 ET44 part number should be 4L0 601 025S (or L - only difference is colour code)
A typical D3 wheel spec in a 20" fitment is 9jx20 ET46
You will have 11mm less clearance on the inside of the wheel and an extra 15mm sticking out on the outside. THAT'S COMPARED TO THE 20" WHEEL SO IF YOU'RE ON 19s WILL BE DIFFERENT
They're going to need to be some massive tyres on those wheels! It's going to knock your speedo out quite a bit unless you go for real rubber band tyres, but I reckon they should fit
