If you are thinking about the Kivic one it cames with both male and female leads so you're covered there.
Indeed that unit you linked to is the same kind of device and may work perfectly well.
As for getting video displayed on you mmi screen Xcarlink sell a product that will connect directly to the screen but you will also need a audio interface, i would go the route of fitting a tv tuner myself but each to there own.
Originally Posted by kele
Interesting. So this can be done with any device that has RCA output leads (red, yellow, white?). Does the car have female RCA inputs then or do I need an adapter?
Is there a good reference guide for installation? Also to understand existing requirements of the car. For example I understand some head-up displays have no video input if the car was not fitted with a TV Tuner or advanced parking camera.
It sounds like I need to remove the Nav DVD player in the boot and have a look at what connections lurk behind? In my case I have no TV tuner but advanced parking should mean that at least I don't need to upgrade my screen...
I see there are other choices for the unit available too. For example here from just £34 delivered (ex import charges) I guess you get what you pay for in terms of the quality and features compared to the Kivic model.... I will explore further
