Quick update to this - the lateral acceleration sensor was put in and scans as working correctly. It appears to have re calibrated itself without doing the esp recalibration excercise. All other codes were eliminated apart from one which was to do with DTC memory on the abs controller. A new code appeared which was confirmed today by Swindon Audi's Master-tech as being caused by a fault in my replacement abs ECU - he confirmed that all remaining dash lights should disappear once this ECU is repaired or replaced. So I am going to send it into a company called bba-reman who refurb the ECU (take it off the abs unit and just send it in on its own). For about £150 they offer a few days turn around and a lifetime warranty once they have done it. I'll report back once this is done
