Old 5th January 2010, 11:25 AM
The D3 is actually a better ride in terms of comfort and reassured handling. The air suspension (when working) means you can alter the suspension dynamically, although of course you need the MMi working to access that, and the MMI stops working as soon as anything else audio related stops working, but thats a seperate grumble....
According to the press release, the D3 is built using less welding joints that the D2 (I forget exactly how many) but the result is noticable. The car does feel firmer, more rigid and in a good way....
I imagine the S8 would be a very capable motor, but with even more electronic-canbus-dependent-take-back-to-Audi-to-fix gadgets as standard kit it wouldnt be long before I fell out with it.
And then, just in case you do happen to have Vagcom, a little time and a hint of skill, component protection kicks in to make sure you cant use components on your car if they were originally used on another car with a different VIN....
We recently picked up a D2 S8 with well over 200K on the clock, which had been replaced (begrudgingly) by a new D3 S8, and they (quote) 'dont like the new one'
Nuff said for me really...
