Old 7th February 2015, 09:20 PM
ChrisM ChrisM is offline
To change the brake pads the caliper needs to be opened using software (vcds) but you would need the cable and a suitable windows laptop to do it.
But being as you are having trouble releasing the hand brake it's likely not to open anyway.
There should be a ikea style crank Allen key type tool in the tool set that can be used to wind the caliper open in the event of electrical failure.
I would have a go at doing that first when you check the electrical connector.
Do not at any time try and squeeze the piston back in like you would on a traditional caliper.
Good luck and welcome from me too.
Del,I checked the electrical connector to no avail ...
so I've decided to take it to a garage not too far from me that has been recommended who are able to do a proper diagnostic check.
Thank you for your advice and the welcome.
