I'm tempted to say that since the "under tray/fox incident" this has caused other parts of your bumper and arch liners etc to move out of alignment so they are rubbing somewhere. The whole under tray system is reliant on everything being correctly connected to everything else and from experience the minute part of the under tray gets damaged or broken and some connectors don't work then other bits move and start to rub and make scuffing noises. That incident may also mean that your park sensor connectors have worked loose or the wiring been damaged somehow.
I would get the car onto a ramp and take a good look to see if there is anything obvious with either.
