Old 9th February 2015, 08:24 PM
tonyt102's Avatar
tonyt102 tonyt102 is offline
Default Gearbox problem.
Got an issue with my gearbox. I've done a fair bit of searching and although there are a lot of problems reported, I can't see any of them which are similar to mine.
A couple of weeks ago, I got a small judder at low speed, gently accelerating up a small hill which has happened a couple of times since. Finished work tonight and went to put the car in drive. It initially engaged but then lost drive. Gave it a slight rev of the engine and with a thud, it came back in. Exactly the same in reverse and when I got it rolling, at very low speed, there was a fair bit of clunking. Once driving the car was perfect. I've even been back out a few hours later, once the car had cooled back down and it doesn't do it. Plugged it in and no fault codes either.
The car is a 2002 S8 with 161k.
Any ideas?
