Thread: A8 Timing out?
View Single Post
Old 10th February 2015, 06:22 PM
Originally Posted by Urbtree View Post
Its never over heated as far as i'm aware in fact it runs very cold most of the time.
I'd be looking at the thermostat or engine coolant temperature sensor if it's been like that for a while.
Not sure what and where that is on a 2.8 but I'd guess it's not that different to a 4.2.
The 4.2 sensor is relatively easy to replace, but a bit of a swine to get at and put back without the risk of losing the retaining clip. I've done it at least 3 times (don't ask!).
Again, if it's the same sensor as a 4.2 it's a pretty common VAG part (green 4-pin type) and I think it actually has 2 sensors in it, one used by the engine management and the other by the instruments.
Don't buy a cheap clone if you do replace it - tenth of the price but a tenth of the quality.
