Does it have auto-dim interior mirror? If not, it shouldn't have dimming exterior as the sensor input for the exterior glass is the interior one and when new you had to specify the interior mirror first, then the exterior auto dimming on top of that. Neither could be had as standard on an FE. We're kind of ignoring the fact most of us have messed with the specs to some degree as well, so although mine's an FE it doesn't have the fixed FE spec any more  Quite possible it's a retrofit either when new or subsequent.
I've seen an FE with red leather where the steering wheel had been swapped for a platinum one - gear selector is another easy one to swap.
Since FE was only for the UK market I don't think there's a definitive way to check? Mine has an unknown spec when it comes to paint code, I just have ----/---- under the AVP engine code, and when you search on ETKA it pulls up a message with an e-mail address for Audi Individual to confirm spec details. Since Avus was only ever offered on FEs it may not apply if the regular paint code was offered anyway?
