Old 11th January 2010, 07:00 PM
Vcds is unlikely to tell you much about the state of the bulbs, but you could try it. The headlight aim controller failing is more common, but that doesnt cause a lack of illumination, so you're either looking at the bulb being faulty, or the ignitor that gets it going (bit like a normal household floresent tube)
You could change the bulbs over from n/s to o/s and vice versa to see which part is faulty.
When you say hi beam still works, I guess you mean on flash, ie pulling the stalk back? - If you push it forward to hold main beam, that should work with the same bulb as dipped beam, and i'd be quite confused if it was igniting for main beam, but not for dipped.... When your 'flash' hi beam works, it should be a seperate Halogen bulb that works for that.
(its the use of the same xenonbulb for main and dipped beam + a seperate 'flash' halogen that makes the xenon plus, plus... !)
Interesting you have a side light out too - Not sure if that was an incidental comment, or part of the diagnostics, but maybe a dodgy earth?
Hope that helps....
