Originally Posted by ainarssems
There is compass in text based SatNav as well, it's under rear parcel shelf and is used to determine heading when there is poor or no GPS signal and distance is taken from ABS sensors. I had imagined all factory SatNavs would work in this manner.
HPSause is talking about a pretty graphical compass on the screen
The RNSC/D and later all use gyroscopes and ABS speed pulses to help when GPS signal is low.
The early Text based nav is the only one I'm aware of that has an actual electrical compass on the parcel shelf. From memory, it also has a relay that switches the compass off, when you turn on the heated rear screen so that it doesn't mis interpret the interference....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
