Thread: Trouble?
Old 26th February 2015, 11:21 AM
As I may have mentioned elsewhere the knocking noises (loud!) are the catalyst, and it needs doing PDQ.
The hesitancy symptoms have got worse in recent days so I'll get the catalyst fixed first to see whether or not it's a factor.
I have also acquired a throttle pedal sender potentiometer (from our sponsors of course ) but will hold off on fitting that for now.
There are references online suggesting that the throttle BODY needs recalibrating (I have done that before while investigating this) after changing the pedal or sender (not 100% sure why) but is there any need or method for calibrating the actual sender on the throttle pedal (I can find nothing about that) or is it effectively "preset" at manufacture?
